Condacut DP 415 Cutting Oil
Due to pending regulations regarding the use of chlorinated paraffins in metalworking fluids, Condat Copr. has introduced a high-performance, chlorine-free cutting oil. The new Condacut DP 415 uses innovative EP additives with an inactive sulphur-based chemistry. The unique formulation provides positive characteristics for all types of machining applications but was specifically designed for screw machining process.
Due to pending regulations regarding the use of chlorinated paraffins in metalworking fluids, Condat Corp. has introduced a high performance, chlorine free cutting oil. The new CONDACUT DP 415 uses innovative EP additives with an inactive sulphur-based chemistry. The unique formulation provides positive characteristics for all types of machining applications but was specifically designed for screw machining process.
Benefits:
Meets or exceeds all EPA current and pending regulations about chlorinated paraffins.
Low viscosity of the CONDACUT DP 415 reduces consumption and allows better cooling.
CONDACUT DP 415 is suitable for all metals and will not stain copper alloys.
The blend of EP additives used in the formulation of CONDACUT DP 415 prevent premature tool wear and provide excellent surface finish.
