CoroMill 419
CoroMill 419
CoroMill 419 from Sandvik Coromant Co. is a new five-edge high-feed milling concept for roughing to semi-finishing, offering excellent performance in all material groups and with great possibilities for optimization.
January 13, 2013
The new milling cutter is suitable for most applications and industry segments requiring high feed face and profile milling. It is well suited to machining of components requiring long overhangs and even perfect for lower-power machines and weak fixtures.
Its benefits include, high productivity in applications requiring light cutting action and long tool life, especially in difficult-to-machine materials with an optimization for stainless steel, hardened steel and titanium.
Through coolant on all cutters enables efficient wet machining and the option of compressed air cooling provides improved chip evacuation in deep cavity milling and helical interpolation.
CoroMill 419 is equipped with strong and robust inserts for reliable machining with five cutting edges. It is available with a wide range of insert grades and geometries, giving you a choice for most materials and applications. CoroMill 419 is available in diameter range 32-100mm (1.25-4 inch).
  • milling cutter
  • interpolation
