The CoroMill QD groove milling tools from Sandvik Coromant Co. are available with Silent Tools adapters for long-overhang machining. The through-coolant grooving and parting tools accept inserts with optimized geometries to effectively evacuate chips. The insert geometry deforms the chips to a narrower shape than the groove, and the coolant then flushes the chips.
- coolant
- grooving
grooving
- parting
parting
When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
