D5 Dental Mill
Datron Dynamics Inc. has announced the release of the DATRON D5 Dental Mill. This 5-axis, high-speed machining center was designed specifically and exclusively for dental milling applications including crowns, bridges, abutments, inlays, onlays, telescopes, implants, bar work and even models. A rigid cast iron construction houses a fully-integrated 5-axis automation system built to hold up to 8 material blanks or "pucks" frequently used by dental labs. This integrated 8-piece handling system loads and unloads blanks for un-attended operation. Finished blanks can be unloaded from the machine while the machine is running.
The DATRON D5 is optimized for the efficient machining of common dental materials such as NEM, titanium, chrome-cobalt, zirconium, PMMA, wax, ceramics and dental gypsum. This machine has 7 dynamic servo drives, cast construction, horizontally-mounted industrial spindle, all of which produce superior and ultra precise parts.
The D5 features a user-friendly touch-screen Apple iPad to control all machine functions. The control software is an open architecture capable of interfacing with all standard scanning systems and CAD/CAM packages. Even the size of the machine was dictated by the needs of dental laboratories and the D5 can fit through a standard 36" x 80" commercial door. The D5 has an integrated lubrication system and dust collection to handle any material being processed. Made in Germany, this machine was launched last month to critical acclaim – winning the prestigious Red Dot Design Award for Best Industrial Design. The D5's touch operator interface (Apple iPad) enables very simple programming of the DATRON Dental software. Since the Apple iPad is removable and can be taken off of the machining center, machine operations and job status can be monitored remotely even from a distance. For example, by activating the Live View button, the iPad screen shows the machining area.
A camera mounted inside the machine transmits the image to the removable iPad screen. This feature allows the operator to check the production status of the machine from another location, such as an office, or perhaps a ceramic station. Within the D5 machining software, the milling data generated by the CAM module is constantly synchronized with the job manager and activated when necessary. Simple Touch functions can link jobs together according to priority and deadline, or they can be run independently if preferred. Integrated blank management stores a library of data about the type and strength of the various materials comprising each individual blank (puck) housed within the automation unit. A plausibility examination is completed before any milling procedure begins. Tool data defining each tool type allows for the simple selection of tools by the CAM module.
Based on the function and machining time for which the tool will be employed, a pre-defined tool exchange (replacement) is scheduled – thereby ensuring ongoing quality control even during unattended operations. An integrated 13-station tool changer features tool-length and tool-break sensors. The milling tools and lubricant provided with the D5 which have been tested and optimized for superior tool life. The turning center of the rotary axis lies directly in the center of the material blank being milled which leads to tremendous rigidity – and contributes considerably to extremely high manufacturing accuracies.
  • ceramics
    ceramics
  • gang cutting ( milling)
  • machining center
    machining center
  • milling
  • milling machine ( mill)
  • turning
