Drilling and threading with the same tool? Even in working depth up to 3 diameters? Yes it is possible, thanks to the new DC Swiss circular thread milling cutter from Mikron Tools with internal coolant starting from 3mm (0.12”).
The innovative improvements compensate the known disadvantages of circular milling. The internal coolant has a double function: Evacuating the large volume of chips and cooling down the cutting edge constantly. The carbide has been chosen to adapt to the tough conditions when drilling and the polyvalent PVD coating is minimizing the tools wear.
- coolant
- milling cutter
milling cutter
- threading
threading
