DrillMeister Exchangeable-Head Drills
Tungaloy expands the drill diameter range of the DrillMeister exchangeable-head drills to include diameters from 8.0 mm to 11.9 mm in 12xD body length.
September 3, 2019
DrillMeister features a unique self-locking interface that assures easy and secure drill head exchange. Since drill heads can be exchanged without removing the entire drill body from the spindle, setup time is significantly reduced, eliminating presetting, offset and touch-off of the replaced tool.
The drill head is mounted or removed from the body by simply twisting the head with a dedicated key wrench while on the machine spindle. In addition, the drill body features optimized helical flutes with a high helix angle and specially treated surface to efficiently evacuate chips from the cutting point to the outside. This makes the tool ideal for deep-hole drilling where chip evacuation is usually problematic.
At a Glance
New drill diameters ranging from 8.0 mm to 11.9 mm in 0.1 mm increments in 12xD body length
High helix angle and special surface treatment on the helical flutes for improved chip evacuation
Easy and secure drill head clamping thanks to innovative self-locking interface
High hole accuracy of solid drills is possible thanks to the drill head with margins
No need for regrinding. Eliminates costs for regrinding and reduces tool management and inventory
Eight drills to be added in this expansion
  • helix angle
