Water jet manufacturer Jet Edge, Inc. introduces the ECO-JET Waterjet Pump. Eco-friendly and budget-friendly, the 55KSI 30hp ECO-JET features an efficient direct drive pump design that consumes up to 40 percent less electricity than a 50hp pump, but produces the same output.
The ECO-JET produces up to 1 gpm of 55KSI ultra-high pressure (UHP) water for precision cutting, cleaning and surface preparation applications. It runs a .015 inch waterjet orifice and can power most manufacturers' waterjet cutting systems and waterjet tools.
- waterjet cutting
waterjet cutting
Fine, high-pressure (up to 50,000 psi or greater), high-velocity jet of water directed by a small nozzle to cut material. Velocity of the stream can exceed twice the speed of sound. Nozzle opening ranges from between 0.004" to 0.016" (0.l0mm to 0.41mm), producing a very narrow kerf. See AWJ, abrasive waterjet.
