![EM Expert Coolant Mist Collector Helps Ensure a Safe Work Environment EM Expert Coolant Mist Collector](/sites/default/files/styles/product_image/public/product_images/EM%20Expert%20300%20dpi.jpg?itok=5yQbGo7c)
When metalworking fluids are used during machining processes, they generate airborne mists that can pose a health and safety risk to workers. To help facilities ensure a safe work environment and regulatory compliance, Camfil APC offers the EM Expert coolant mist collector.
The EM Expert is suitable for applications that use cooling lubricants such as turning, drilling, milling, roughing and grinding. This high-efficiency collector separates ultra-fine coolant mists and fumes and is available with an optional HEPA final filter stage to collect particulates less than 1 micron.
Its functional design makes the EM Expert practically maintenance free. Quick-acting clamps ensure easy filter cartridge changes that require no tools. Filter cartridges are accessed via the service door(s) and a transport trolley is available for drip-free removal of the filter cartridges.
The EM Expert mist collector unit is delivered ready for plug-and-play without any additional assembly required during installation. Its modular design enables it to be customized to suit a facility’s current needs and future expansion. It also comes with a no-leak guarantee.
- coolant
- grinding
- metalworking
metalworking
- micron
micron
Measure of length that is equal to one-millionth of a meter.
- modular design ( modular construction)
- turning
