EXOCARB ADF Flat Drills
OSG offers the new EXOCARB ADF flat drills. Machining a flat hole traditionally required the use of an endmill and a drill. The ADF drill enables one-step drilling to simplify machining time and tool management.
OSG offers the new EXOCARB ADF flat drills. Machining a flat hole traditionally required the use of an endmill and a drill. The ADF drill enables one-step drilling to simplify machining time and tool management. It is suitable for a wide variety of drilling applications including inclined surfaces, curved surfaces, counterboring, eccentric holes, half-hole and thin plates.
One of the prominent features of the ADF drill is EgiAs coating. It suppresses friction with the wear resistance layer and prevents breakage with the nano periodical layer. In addition, ADF's balanced form and cutting edge enable reduced cutting forces with smaller chips and stable hole entry.
When the ADF drills and conventional drills are compared in counterboring and processed over the center of a pre-existing hole, both drills show little to no positional inaccuracies. However, when it is necessary to process the drill off-center over a pre-existing hole, the position and straightness of the hole made with the ADF drill is five times more accurate than the conventional drills, according to the company.
Also, the ADF drill minimized the amount of shift when drilling a half-hole as compared to both the conventional and competitor drills. Even when drilling on an inclined surface, the ADF drill maintained accurate hole position and resisted chipping.
