Extreme Metal Band Saw Blades
Milwaukee Tool says its Extreme Metal Band Saw Blades cut two times faster and last three times longer than standard blades in thick and thin metals. When it comes to band saw blades, the biggest user frustration is the frequency of changing out the blade. Milwaukee's new blades solve this frustration through a combination of enhanced high-speed steel and a variable TPI tooth design, making two times faster cuts in thick metals and achieving three times longer life in stainless steel. These features also unlock the ability to cut through cast iron.
The Extreme Metal Band Saw Blades will be available in two variations: Thick Metal Blade and Thin Metal Blade which are both available in all portable Milwaukee band saw sizes. The Thick Metal Blade (8/10 TPI) is optimized to provide best-in-class performance when cutting through thick/extreme metals such as black pipe and angle iron but has the additional versatility to cut common thin metals. The Thin Metal Blade (12/14 TPI) is optimized for best-in-class cuts in thin/extreme metals such as unistrut or EMT conduit but also provides strong performance in tougher thick metals.
The aggressive variable-pitched tooth design of these blades delivers the versatility to cut a wide range of materials with just one blade, providing long life in common and extreme materials such as strut, conduit, angle iron, threaded rod, and pipe, and even materials like stainless steel and cast iron.
With the introduction of the new Extreme Metal Band Saw Blades, Milwaukee Tool continues to demonstrate its commitment to delivering user-driven accessory solutions that save time and increase productivity on the jobsite.
Available Models
Thick Metal
• Deep Cut 8/10 TPI Extreme Metal Band Saw Blades – 3PK (48-39-0601)
• Deep Cut 8/10 TPI Extreme Metal Band Saw Blades – 25PK (48-39-0605)
• Deep Cut 8/10 TPI Extreme Metal Band Saw Blades – 100PK (48-39-0602)
• Compact 8/10 TPI Extreme Metal Band Saw Blades – 3PK (48-39-0609)
• Compact 8/10 TPI Extreme Metal Band Saw Blades – 25PK (48-39-0606)
• Compact 8/10 TPI Extreme Metal Band Saw Blades – 100PK (48-39-0607)
Thin Metal
• Deep Cut 12/14 TPI Extreme Metal Band Saw Blades – 3PK (48-39-0611)
• Deep Cut 12/14 TPI Extreme Metal Band Saw Blades – 25PK (48-39-0615)
• Deep Cut 12/14 TPI Extreme Metal Band Saw Blades – 100PK (48-39-0612)
• Compact 12/14 TPI Extreme Metal Band Saw Blades – 3PK (48-39-0619)
• Compact 12/14 TPI Extreme Metal Band Saw Blades – 25PK (48-39-0616)
• Compact 12/14 TPI Extreme Metal Band Saw Blades – 100PK (48-39-0617)
• Subcompact 12/14 TPI Extreme Metal Band Saw Blades – 3PK (48-39-0711)
