Filter Systems
Filter Systems
Eriez Hydroflow offers complete filter system products for a variety of metalworking applications, including standard machining, conventional grinding, creep feed grinding and CBN grinding/machining.
Eriez Hydroflow offers complete filter system products for a variety of metalworking applications, including standard machining, conventional grinding, creep feed grinding and CBN grinding/machining. These products are for metalworking operations that require practical and economical solutions for extending coolant life to help maintain maximum equipment performance.
Machining: Eriez Filters with Synthetic Permanent Media, Wedge Wire, Disposable Roll Media or Cellulose Pre-coated Microscreen can filter as low as oneµm and are available with low pressure flood coolant or high pressure directed coolant. These filters are specifically designed for drilling, milling, boring and turning operations that require significant volumes of flood coolant to move chips from the work area to the coolant sump. Modern machine tools now operate at higher speeds and increased feed rates, intensifying the need for high pressure clean coolant at the tool. Eriez has experience with scalping conveyors used as a pre-filter for large volume and difficult chips. The company has designed mounted filters fed by in-ground flume and floor mounted systems fed by overhead pipes using its custom Chip Transfer Sumps.
Conventional Grinding: Centerless, ID/OD, surface, form and other types of conventional grinding are ideal applications for Eriez filters. For flow rates of 40 GPM to 1200 GPM and filtration to 10µm, the Permanent Media Vacuum Filtration System offers the most advantages over other types of filters available today. The Star Filter handles applications requiring finer filtration to oneµm and/or higher flow rates to 6000 GPM.
Creep Feed Grinding: The Company has been building vacuum filters for creep feed grinding applications since 1986. Eriez Hydroflow supplied the industry's first central system for creep feed grinding in 1990, servicing 20 large Blohm Grinding Cells with a total flow requirement in excess of 2000 GPM.
CBN Grinding/Machining: Perhaps the fastest growing and most difficult filtration application in modern metal working is the CBN Grinding/Superabrasive Machining process. This high-speed process of metal removal requires the use of heavy oils at very high pressure (up to 1000 PSI), resulting in aeration and cavitation problems. Plus, the hard nature of the CBN produces swarf with very little particle size distribution, resulting in blinding and short cycling.
