Giddings & Lewis V Series Vertical Turning Centers
The new Giddings & Lewis V Series from Fives Machining Systems is a versatile line of vertical turning centers for shops looking for a dependable, multi-purpose lathe capable of handling a wide range of parts, including pumps, valves, gears, bearings, compressors, wheel hubs, jet engine housings and more.
All six models, with table sizes ranging from 800mm to 2500mm, have a hydrostatic ram that adds rigidity for heavy cutting and produce less friction for improved part finish. The hydrostatic wear-free guides require less maintenance. The infinitely adjustable cross rail is a programmable positioning axis able to handle a wide range of parts and minimize ram extension. Dual scale feedback delivers precision and ensures parallelism while the hydraulic cylinder elevation adds secure 1000 kN (225,000 lb) of mechanical clamping force per side.
"The V Series is engineered to be flexible, reliable and affordable in response to feedback from our job shop customers," said Brad Nelson, V Series Product Manager at Fives Giddings & Lewis. "All models have a compact footprint, and there is no requirement for special foundations, so the machine can be easily relocated, if necessary. We encourage customers to compare the capabilities and value of the V Series, and we're confident these new machines will impress."
The Giddings & Lewis VLock tooling system provides a stiff interface for modular tooling adaptors, long cutting tools and the optional heavy-duty, right-angle milling attachment. Modular turning tools more than double the taper stiffness at loads up to 1800 Nm," added Nelson. Standard modular tools offer significant savings over the proprietary vertical lathe tooling offered on most vertical lathes, he added. "Modular tools are also lighter, easier and safer to handle, requiring less time to maintain."
Through-the-tool coolant and 8 bar (116 psi) flood coolant is standard, as is a 12-position tool storage disk. Options include 70-bar (1015-psi) high-pressure coolant and an 18-tool storage disk. Other options include tool and part probes to increase utilization and ensure part quality, and enclosures from standard to fully enclosed.
The V Series is designed and built at the Fives Giddings & Lewis plant in Fond du Lac, Wis., and stays true to Giddings & Lewis design traditions, with solid cast iron base construction and versatility offered by optional live spindle attachments and a C-axis table. "By adding the V Series, starting with 800mm tables, to our existing VTC Series of vertical turning centers, with swings up to 9 meters, we are positioned to offer manufacturers the broadest and best range of turning solutions, said Kevin Lichtenberg, Fives Giddings & Lewis Vice President and General Manager.
