![G.W. Schultz tools available with 4, 5 or 7 flutes G.W. Schultz tools available with 4, 5 or 7 flutes](/sites/default/files/styles/product_image/public/product_images/GWSchultz_hgw_4_fmt.png?itok=qe4OfjC5)
G.W. Schultz Tool Inc.’s HGW series tools are available with four, five or seven flutes and are for machining high-temperature alloys, tool steel and most stainless steel alloys. Designed for high-efficiency machining, the nACo-coated tools are suitable for full slotting, climb milling and dry cutting with a high feed. According to the company, customers increased tool life 10 to 30 percent while spending 5 to 30 percent less money.
- alloys
alloys
- climb milling ( down milling)
Rotation of a milling tool in the same direction as the feed at the point of contact. Chips are cut to maximum thickness at the initial engagement of the cutter’s teeth with the workpiece and decrease in thickness at the end of engagement. See conventional milling.
- feed
- flutes
flutes
- slotting
slotting
Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
