High-Feed Cutters
High-Feed Cutters
NTK Cutting Tools offers a line of high-feed cutters (HFC) for milling aluminum. This series maximizes teeth/cutter, from seven teeth on the 50mm-dia. cutter to 22 teeth on a 125mm-dia. cutter, to reduce production time.
June 9, 2016
The lightweight construction allows more customers to utilize this product (the 125mm cutter weighs only 2.4 lbs) and obtain speeds up to 20,000 rpm. The coolant-through mounting bolt provides excellent chip evacuation.
