hyperMILL 2020.2 CAD/CAM Software Suite
New features include the addition of plunge-milling cycles to the 3D and 5-axis strategies for machining cutting edges. Material is removed by plunging movements to reduce vibration and improve surface finish, especially helpful for machining edges with steep walls. When 5-axis machining, undercut areas can also be reached by specifying the lateral inclination on the tilted tool. By specifying a distance, circular or linear movement profile, the tool is optimally retracted from the part.
June 20, 2020
OPEN MIND Technologies AG, a leading developer of CAD/CAM software solutions worldwide, has introduced its latest hyperMILL® 2020.2 CAD/CAM software suite which offers users new and enhanced features for efficient 3D and 5-axis machining, such as the hyperMILL® AUTOMATION Center Advanced option and more.
Due to an enhanced mirror path function, users have shorter calculation times and improved process reliability. The mirror path function now enables simple mirroring of previously calculated toolpaths so the machining direction is also mirrored to effectively make climb milling a conventional milling process. hyperMILL® also retains the original strong mirror function where toolpaths for symmetrical components are recalculated on the basis of mirrored geometry data.
"We continue to improve the hyperMILL® user experience with new, optimized strategies, as well as provide easier to use interfaces and even more efficient filtering and feature management functions," said Mr. Alan Levine, Managing Director of OPEN MIND Technologies USA, Inc. "Also, enhanced functionality in our Mill-Turn, hyperCAD® -S and AUTOMATION Center modules are all key to continually improving the user experience and increasing machining productivity."
When 3-axis simultaneous mill/ turning, inserts including round, rhombic, T, and W can now be used. Also, unlocking the potential to reach particularly difficult areas, a new function controls the approach and retract movements by applying user-defined curves for turning strategies.
A hyperMILL® AUTOMATION Center Advanced option offers numerous additional features and extensive templates to the software's automation capabilities. Templates allow the user to define and standardize complex processes independent of the specific geometry from any one CAD model. All the individual steps for data preparation and programming are defined for applying them to a new model and automatically executing them. For exceptional efficiency, the user is interactively guided through the automated process steps, and can be prompted to make relevant choices during the automation sequence if desired.
Components can now be modeled parametrically directly in hyperCAD® -S, especially helpful for fast, production-related designs. Parametric geometry data used in hyperMILL® is associatively linked, and when there are any changes, is automatically updated.
