Insert Grades for C-Cutter Mini, C-Centering Cutter and Fullcut Mill
BIG KAISER has released a new set of insert grades for its indexable tools—C-Cutter Mini, C-Centering Cutter and Fullcut Mill. The new inserts are optimized to extend tool life in stainless steel or aluminum.
Suited for peck-drilling, ramping, helical and shoulder milling, the Fullcut Mill is now available with the PVD-coated carbide ACP300 with nanometer-level thickness and ultra-multilayered TiAIN and AICrN film, replacing the ACZ350S for general steel applications. The new ACM300F is designed specifically for stainless steel work. The ACM300F boasts excellent fracture and welding resistance and has demonstrated a lifespan 1.5 times of conventional inserts in testing.
The new ACM250F stainless steel grade can be used for chamfering and spot drilling with the C-Cutter Mini or C-Centering Cutter. PVD-coated carbide with excellent smoothness, the new grade resists welding and chipping due to the ultra-multilayered thin film structure made of AlTiN and TiAlCrN. The ACM250F replaces the ACZ150 used with the C-Centering Cutter.
The DS20 for aluminum/nonferrous metals is available for the first time for the C-Centering Cutter. Its diamond-like DLC coating is ultrasmooth with a low wear coefficient and superior welding resistance, and effectively prevents burrs.
