![](/sites/default/files/styles/product_image/public/product_images/SecoJabroSolid2JS534.jpg?itok=tce1Ih6n)
The latest Jabro-Solid2 JS530 Series of ball nose cutters from Seco brings increased flexibility, speed and efficiency to copy and profile milling, as well as slotting and side milling operations.
Consisting of the JS532, JS533 and JS534, the Jabro-Solid2 JS530 series is ideal for 2.5D and 3D machining applications in a broad range of materials, including steel, stainless steel, cast iron and titanium. All geometries are available in normal, long and extra long lengths.
Overall features of the JS530 series include radial relief for strong cutting edges, a polished Siron-A coating for reducing friction and heat buildup, increased core diameters related to the number of teeth for added stability, and edge prep for a controlled wear pattern.
Manufacturers incorporating the JS530 ball nose cutters benefit from stronger flutes for improved process stability, increased tool life, better surface finishes, accurate workpiece dimensions at higher feed rates and reduced re-work.
JS532 employs two flutes and cutting diameters that range from .031" to .750", easily handling roughing, semi-roughing, semi-finishing and finishing applications. JS533 features the same cutting diameters as the JS532, but uses three flutes for semiroughing, semi-finishing and finishing applications. Lastly, JS534 handles semifinishing and finishing applications with four flutes and a cutting diameter range of .063" to .750".
- feed
- flutes
flutes
- relief
relief
- slotting
slotting
Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
