M4258 Modular Helical Milling Cutter
The M4258 modular helical milling cutter from Walter, the most recent addition to its M4000 family of high-performance helical milling cutters, brings cost efficiency and excellent process reliability to slot milling, and can be used for ramping, pocket milling, shoulder milling and circular interpolation as well. Versatility also extends to materials, handling ISO material groups P, M, K and S.
Tiger-tec Gold and Six Tiger-tec Silver grades are available, covering nearly all ISO groups. The modular design of the M4258 features an exchangeable front-end piece that can be replaced when this section of the body is worn or damaged. Precise and safe positioning of the front-end is assured due to its tongue and groove connection with the register pin. Features like this, combined with four/two cutting edges per insert, boost cost efficiency and reduce procurement and inventory costs and requirements.
Process reliability is enhanced by several features. Starting with a half-effective design and highly positive insert geometry, lower power requirements and costs that offer a strong advantage. An internal coolant supply in the standard offering adds versatility, along with superior chip removal. Operating under low cutting pressure, its compact length and effective design promotes smooth operation. This reduces oscillation and vibration, making it a solution for a variety of unstable machining conditions. The M4258 has an approach angle of 90° and a diameter range of 2.0, 2.5, and 3.0 in. (50, 63, and 80 mm). Interfaces are Walter Capto C6 and C8.
  • approach angle
    approach angle
    Angle between the insert’s side-cutting edge and the line perpendicular to the milling cutter’s axis of rotation. Approach angle, which is also known as cutting edge angle, is used with metric units of measurement. See lead angle.
  • coolant
  • gang cutting ( milling)
  • interpolation
    interpolation
  • materials handling
    materials handling
    Methods, equipment and systems for conveying materials to various machines and processing areas and for transferring finished parts to assembly, packaging and shipping areas.
  • milling
  • milling cutter
    milling cutter
  • modular design ( modular construction)
