MCR-BV Machining Center
Designed as a machine for 5-face machining applications, the MCR-BV is also capable of 5-axis contouring as well as 5-sided heavy milling applications. These heavy-duty applications are made possible through features such as a powerful integral motor and spindle, an expanded work envelope, and a very rigid table which is 30% thicker than previous models, all of which is ideal for large-part machining. An abundant range of attachment heads are compatible with the machine, allowing for a wide range of unique part shapes to be created, as well as many multitasking machining functions to be performed.
November 30, 2021
The leadership team of Okuma America Corporation is excited to announce the debut of a new double-column machining center (DCMC). This new machine – the MCR-BV - is the seventh machine offered in the company's double-column machine line-up.
Additional machine features include a fast automatic tool changer (ATC) and a smaller, faster auto attachment changer (AAC), both of which allow this DCMC to greatly increase productivity while performing heavy cutting or high-accuracy finishing.
Key Specs of the MCR-BV Double-Column Machining Center:
  • Table Size mm (in): 2,000 x 4,000 (78.74 x 157.48) to 3,000 x 12,000 (118.11 x 472.44)
  • Spindle Speed min⁻¹: 6,000 [10,000 option also available]
  • Spindle Motor Power kW (hp): 43 (57)
  • Rapid Traverse m/min (fpm): X: 30 (98.43), Y: 32 (104.99), Z: 15 (49.22)
  • Magazine Capacity: 50, 80, 100, 120 or 180 Tools
  • machining center
  • rapid traverse
  • work envelope
