MFPN facemill
MFPN facemill
Kyocera Industrial Ceramics Corp., Cutting Tool Div.'s MFPN facemill accepts PNMU inserts, which have a double-sided, pentagonal design that provides 10 cutting edges per insert.
Kyocera Industrial Ceramics Corp., Cutting Tool Div.'s MFPN facemill accepts PNMU inserts, which have a double-sided, pentagonal design that provides 10 cutting edges per insert. The combination of the tough, dual-angle edge and the 10° positive axial rake angle allows the facemill to run at a high feed rate, according to the company.
