MFWN-Mini
MFWN-Mini
The additional cutter designs feature a smaller 5mm D.O.C. insert size with the same cost-efficient, double-sided, 6-edge design from the M-SIX line. The M-Six double-sided, 6-edge insert milling cutters with tough cutting edge due to wide design.n
October 3, 2020
Introducing a smaller, economical diameter range for the M-SIX (MFWN) series milling cutters. The additional cutter designs feature a smaller 5mm D.O.C. insert size with the same cost-efficient, double-sided, 6-edge design from the M-SIX line.
Face Mills: ø50mm ~ ø125mm
End Mills: ø25mm ~ ø80mm
Advantages
  • Sharp Cutting with Low Cutting Forces
    Low cutting forces due to steep rake angle. (A.R. Max+13°)
  • Reduced Chattering
    Even with extended milling adapters
  • Superior Fracture Resistance
    8.5mm~5mm thick cutting edge with stable clamping due to unique face design
  • Neutral Inserts
    Available for shouldering and facing with neutral inserts applicable for left-hand cutters (custom order).
  • MFWN-Mini
    Smaller diameters now available with the new MFWN-Mini lineup expansion.
