A wide range of cutter blades for its full line of portable pipe beveling machines that pull a thick chip without cutting oils to promote high weld integrity has been introduced by Esco Tool. Esco MILLHOG cutter blades feature sharp edges and a radical chip breaker that can bevel the pipe OD, flat face and bore the ID sumultaneously without cutting oils.
Available in 37-1/2° and 30° standard OD angles or any angle of prep from 10°, plus compound bevels, they are made from T-15 tool steel and are TiN-coated for extended blade life or are hard lube for superior heat resistance and longer blade life on highly alloyed materials.
Ideal for heavy-wall pipe made of Super Duplex stainless steel, P-91, and other hard super-alloys, Esco Millhog cutter blades mount securely in the tools using the EscoLock wedge-style rigid blade lock system. These cutter blades are available for the entire line of Millhog pipe milling end prep tools for tube and pipe from 0.5” ID to 36” OD.
- flat ( screw flat)
flat ( screw flat)
- inner diameter ( ID)
- outer diameter ( OD)
