R-Cutter and BF-Cutter
BIG Kaiser Precision Tooling Inc. introduces the R-Cutter (Pat. P) and BF-Cutter from BIG Daishowa.
March 13, 2013
BIG Kaiser Precision Tooling Inc. introduces the R-Cutter (Pat. P) and BF-Cutter from BIG Daishowa. The R-Cutter is an ultra high feed front and back radius chamfering mill which features high rake angles that reduce cutting resistance and minimize burr generation. The radius chamfering mill is offered as a single-insert design and a four-insert design for higher feed rates.
The coated carbide insert design allows for four indexes, is available with radii of 0.02" to 0.16", and is optimized for all steels (including stainless), cast iron and aluminum. A variety of R-Cutter types are available, including a single insert front chamfering-only design with shank diameters of 16mm and 20mm, and front-and-back combination chamfering models with cutting shank diameters of 10mm, 16mm and 32mm. Each model featuring a single insert design allows for cutting in the tightest of spaces.
The BF-Cutter was exclusively designed for back spot facing of cap bolt holes, sizes M6-M16. It features the a small square indexable insert (with 4 indexes), and is for all steels (including stainless), cast iron and aluminum. The coolant-through capability helps cool down the back side cutting area, increasing tool life. The BF-Cutter is available for minimum facing diameters beginning at 0.433" and up to 1.024". A unique, offset design allows for easy programming; simply offset the centers between the machine spindle and the hole when entering or exiting the hole with the cutter. The minimum hole diameter for possible entry is 0.256".
"Whether front or back radius chamfering, or back spot facing bolt holes, these new cutters from BIG Daishowa with very unique features are great additions to any shop's tool arsenal in that they optimize productivity for any applicable operation they are called up for," says Jack Burley, vice president, sales and engineering, BIG Kaiser. "Both tools are available from BIG Kaiser's new Indexable Cutting Tools Catalog, which details BIG Daishowa's entire line of high performance indexable cutting tool systems."
  • indexable insert
    Replaceable tool that clamps into a tool body, drill, mill or other cutter body designed to accommodate inserts. Most inserts are made of cemented carbide. Often they are coated wi…
  • chamfering
