REGO-FIX is introducing the new REGO PLUS line of toolholders. Fully compatible with all BIG PLUS spindles, these new toolholders are licensed by BIG Daishowa. The new REGO PLUS product series will include a full line of ER system toolholders, as well as a full line of powRgrip system toolholders. All products in the line are made by REGO-FIX at its Switzerland manufacturing facility and hold to the strict Swiss standards that the company is known for. The new REGO PLUS line offers several advantages to manufacturers working with high precision milling machines equipped with the BIG PLUS system. These include better TIR, improved tool stiffness, increased quality of surface finishes and higher machine accuracies. All REGO PLUS products are designed for form B coolant and accommodate through-the-taper coolant as a standard feature.
- coolant
- stiffness
stiffness
- total indicator runout ( TIR)
Combined variations of all dimensions of a workpiece, measured with an indicator, determined by rotating the part 360°.
