Robot Easy 800
Robot Easy 800
Workpieces with a maximum weight of 800kg and a size of up to Ø850 mm x 1,000 mm can be loaded onto the machine tool safely and reliably. The Robot Easy 800 is optimally suitable for moving pallets from our EROWA MTS system, which are predominantly used for milling and grinding.
February 26, 2020
The workpiece magazine can be configured with up to 12 magazine positions when using the EROWA MTS 400 workpiece carrier pallets (400 mm x 460 mm). The magazine plates can be rotated which makes it easier to fit palletized fixtures and tombstones with workpieces directly in the Robot magazine. The maximum magazine capacity is 7.0 tons.
With its compact monobloc design which requires only 20 sq. ft. of floor space, the Robot Easy 800 can be positioned by the machine, installed and made operational in no time. If production needs change, the function and magazine positions can be adapted to suit these requirements.
The stable transfer axis has a reach of 2,000 mm from the Robot's outer edge. This leaves sufficient space for manual work on the machine. The robot can serve machine table heights between 765 mm and 1,200 mm.
