Seco Assistant App
Seco Assistant App
Seco Assistant's machining calculator gives you turning, milling and holemaking data for any brand including feeds, speeds and material removal rate. The Tool Comparison function gives you Seco tool recommendations and alternatives to other manufacturer's inserts, while the Suggest function helps you find the right tooling option and cutting strategies for specific jobs.
Seco Assistant puts the product information and tools you really need at your fingertips without the need for internet searches or catalog research, even when you are offline.
You can search for products by item, number, designation, or grade or simply scan the code on the packaging.
The app is developed for maximum convenience and ease of use, with a small download size and a clean, clear interface. Crucially, if you don't have an internet connection you can also search for Seco products or use the data calculators offline.
Seco Assistant streamlines your daily machining experiences, combining vital information and tools with the smoothest of user experiences. With easy to navigate practical tools, it puts the information you really need at your fingertips.
