SLOTWORX HP Milling System
The SLOTWORX HP milling system from POKOLM Frästechnik GmbH & Co. KG, with its new shoulder facemilling inserts where r = 0.8 mm, is known for its high performance in the high-feed range. The symbiosis of an especially innovative insert geometry, with the proven carbide and an extremely smooth and wear-resistant coating, guarantees long tool life when it comes to finishing vertical and plain surfaces, according to the company.
At the same time, the positive angle of twist in the mounting position ensures minimum drift. Both soft materials and hardened steels can be machined with the same high degree of performance thanks to the positive protective chamfer and the positive rake angle. Even the machining of high-temperature alloys, such as Inconel and titanium, is possible without limits when these cutting materials are used.
Thanks to its small dimensions from 10 mm in diameter onwards, SLOTWORX HP can even substitute solid-carbide tools in certain subareas.
SLOTWORX HP is suitable as a square shoulder and slot milling cutter when the standard working depth of solid-carbide corner radius milling cutters is no longer sufficient and lateral surfaces and bottoms in small pockets or molds and mold inserts, for example, are to be finished.
