![Sphinx Nirox Sphinx Nirox High-Performance Drill](/sites/default/files/styles/product_image/public/product_images/sphinx-nirox-rgb.jpg?itok=TGZ4I6PZ)
BIG KAISER Precision Tooling introduces the Nirox high-performance drill from Sphinx, the newest addition to its cutting tool lineup. Available in diameters from 0.30-3.00mm, the Nirox was developed for use at low cutting speeds in unstable environments. The Nirox geometry has a degressive helix angle equal to 30 degrees at the point and is designed for accurate and precise hole location up to 9xD.
A modern, TiAlSiN based coating allows for enhanced chip and coolant evacuation in difficult to machine and adhesive materials, such as titanium, Inconel, stainless steel, hardened steel and CoCr alloys.
- alloys
alloys
- coolant
- helix angle
helix angle
