![Tung-AluMill Line of Indexable Shoulder Milling Cutters Expanded Tung-AluMill Indexable Shoulder Milling Cutters](/sites/default/files/styles/product_image/public/product_images/Tung-AluMill_Expansion.jpg?itok=j5XsHNqg)
Tungaloy has expanded its Tung-AluMill line of indexable shoulder milling cutters to include an insert with a 2.5 mm (0.1") nose radii.
The Tung-AluMill line of indexable square shoulder milling cutters features V bottom inserts and secure insert retention, enabling high-speed milling of aluminum alloys and other nonferrous materials. This cutter ensures stability and efficiency in shouldering, slotting and profiling applications at elevated cutting speeds.
The use of lightweight, high-strength aluminum alloys is increasing across many industries to reduce environmental burdens. More specifically, the aerospace industry is using aluminum alloys for large aircraft components to meet weight reduction requirements for improved fuel efficiency. Tung-AluMill’s new 2.5 mm nose radius insert enhances its comprehensive lineup of insert radii preferred by aircraft component manufacturers to boost productivity and cost effectiveness.
At a glance:
Process security at high revolutions: insert bottom ensures centrifugal protection and secure milling process
High efficiency: cutting edge toughness and fracture resistance enable milling at higher feeds and speeds
One insert to be added: XVCT160525R-AJ TH10
- alloys
alloys
- aluminum alloys
aluminum alloys
Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wrought compositions and casting compositions. Some compositions may contain up to 10 alloying elements, but only one or two are the main alloying elements, such as copper, manganese, silicon, magnesium, zinc or tin.
- profiling
profiling
- slotting
slotting
Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
