TungForce-Rec 12
TungForce-Rec 12 Offers Coarse Pitch Cutters
Tungaloy has added eight coarse pitch cutters to its TungForce-Rec 12 square shoulder milling cutter line. Featuring extremely rigid cutter bodies, the cutter line provides unbeatable machining efficiency for square shoulder milling operations. The new cutters are offered in imperial sizes.
In general shoulder milling operations, tool rigidity plays a critical role in achieving close tolerances and part consistency. The new coarse pitch cutters retain a prominent feature of TungForce-Rec that provides maximum tool rigidity during demanding operations. In addition, flutes on the cutter body are designed with large chip space to promote smooth evacuation, preventing chips from clogging during operations. TungForce-Rec 12 coarse pitch cutters provide excellent tool reliability and process security, enabling chatter-free, stable machining.
  • flutes
    flutes
  • gang cutting ( milling)
  • milling
  • milling cutter
    milling cutter
  • pitch
    pitch
