Turbo 10
Turbo 10
Seco Tools has released another advancement for the square shoulder milling process with its new Turbo 10 cutting tool that is suitable for most roughing, semi-finishing and finishing operations.
November 1, 2011
Seco Tools has released another advancement for the square shoulder milling process with its new Turbo 10 cutting tool that is suitable for most roughing, semi-finishing and finishing operations. The cutter offers improved tool life and precision by optimizing cutting properties that reduce heat generation and cutting forces.
As a highly versatile design, the Turbo 10 easily tackles slotting, contouring, helical interpolation and ramping applications with cutting diameters that range from 0.625" to 4" and a maximum cutting depth of 0.354".
The Turbo 10 employs a coated, pre-hardened cutter body with two different pitch configurations for meeting tight tolerances and providing high reliability. Mounting types for the Turbo 10 include Cylindrical, Weldon, Arbor and Combimaster.
With strong, highly positive geometries, optimized edges, a wide range of industryleading carbide grades and two different corner radii, the inserts used in conjunction with the Turbo 10 offer maximum levels of adaptability, accuracy and reliability. Furthermore, inserts can be set to a true 90°Cutting angle to create clean 90 degree walls and eliminate secondary operations. Inserts lock into place via a strong center screw placed in the same direction as cutting forces, and wiper flats optimize surface finishes.
  • interpolation
