Turbo 10 Miling Cutters
To continue the success of its Turbo 10 series of square shoulder milling cutters and provide manufacturers with increased machining flexibility in tough materials, Seco Tools is expanding the product line to include more inserts with new geometries and radii as well as helical cutters.
The insert range expansion includes both direct pressed and ground insert alternatives with corner radii ranging from 0.016" to 0.122" (0.4mm to 3.1mm). The new geometries for the ground insert range provide increased performance in materials with unique challenges, including aluminum, stainless steels, titanium alloys and other difficult-to-machine alloys.
The new helical cutters are ideal for helical shoulder milling applications that require process stability, flexibility and high precision. The cutters are available in diameters ranging from 0.75" to 2" (20mm to 54mm) and include Weldon, Seco Weldon, Combimaster heads, Seco-Capto and Arbor mounting options.
All Turbo 10 cutters include precision milled pocket seats that improve run-out, stability and tool life by providing optimal contact between the tool body and insert. Integrated through-coolant channels support high productivity and promote excellent chip evacuation. Because of their high levels of flexibility, Turbo 10 cutters work in slotting, shouldering, ramping, facing, pocketing, plunging and turn milling applications.
  • alloys
    alloys
  • arbor
    arbor
  • gang cutting ( milling)
  • milling
  • slotting
    slotting
    Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
  • stainless steels
    stainless steels
