X.mill M 900 Vertical Machining Center
Knuth Machine Tools USA Inc. says its X.mill M 900 provides long life and has a 30-bar ICS system (inside coolant supply).
The machine ensures efficient production and features:
• Mineral-casting machine base with cast-iron stand
• Mineral-casting reduces vibration 6 times faster than cast-iron and up to 10 times faster than steel,
ensuring exceptionally quiet operation, excellent milling capacity and superior
• Superior mechanical properties of the total component package ensure longer tool life
• 10,000-rpm main spindle drive is standard
• Spindle oil-cooler ensures stable thermal conditions during continuous operation
• Precise linear roller guides on all axesfeature reliable stainless steel protective covers
• Precision preloaded ball screws and powerful servo-drives on all 3 axes
• Dual-arm tool changer for quick and precise tool changes
• Enclosed work space ensures safe and contamination-free work
• An electronic hand-wheel and very accessible work table for easy setup of clamping
tools and workpieces
• LED lighting ensures good visibility in the workspace
• Effective coolant system ensures optimal use of tools and excellent chip removal
• An automatic lubrication system reduces the operator's workload and simplifies
maintenance
• Chain-type chip conveyor with 47 inch high ejector ensures efficient chip removal
