Xtra·tec XT M5460
Xtra·tec XT M5460
Walter has introduced the Xtra·tec® XT M5460, a new profile milling cutter that delivers maximum precision, tool life, and surface quality in precise machining of freeform surfaces and deep cavities.
This new profile milling cutter now provides an internal coolant channel, enabling chip evacuation using compressed air or MQL. This is necessary for deep pockets as it allows the user to evacuate the chips.
The Xtra·tec® XT M5460 has been specially designed for difficult materials, particularly for hard machining of steels up to 63 HRC. Alongside the proven geometries of Walters P3201 and P3204 indexable inserts, Walter is now offering these strong inserts in our newest grade WHH15X for hard machining. In field tests, the new M5460 with this latest grade WHH15X, achieved increases in tool life of up to 500%.
Thanks to the addition of this new grade to the existing range of cutting tool grades and geometries, this profile milling cutter is proven to be very effective in Steels (ISO P), Cast Irons (ISO K), Stainless Steels (ISO M) and Hard Materials (ISO H). This means that, in addition to mold and die making, it also offers advantages for the aerospace and energy industries with its high productivity, maximum process reliability, and cost effectiveness.
Walter offers the Xtra·tec® XT M5460 with both Weldon and cylindrical shanks, as well as with the industry standard cylindrical modular interface.
Walter is initially launching the milling cutter for diameters: 3/8 -1 in. and in metric from 8-32 mm.
  • cast irons
    cast irons
    Cast ferrous alloys containing carbon in excess of solubility in austenite that exists in the alloy at the eutectic temperature. Cast irons include gray cast iron, white cast iron, malleable cast iron and ductile, or nodular, cast iron. The word “cast” is often left out.
  • coolant
  • gang cutting ( milling)
  • milling
  • milling cutter
    milling cutter
  • stainless steels
    stainless steels
