Connect, Cut, Automate, Win
Published Date
November 30, 2018 - 11:00:am
While the MU-S600V’s compact footprint can be misleading, this flexible, 55-inch, 5-axis vertical machining center will have a dramatic impact on your overall productivity. Designed to connect with multiple machines, the MU-S600V allows manufacturers to create unattended and automated production line processes. In fact, when you set two MU-S600Vs side-by-side, their built-in robotics allows them to pass parts back and forth using our cutting-edge work handoff system. The MU-S600V also boasts a 16-station ATC with an optional 30 chain for increased efficiency, as well as Okuma's Thermo-Friendly Concept and Thermal Active Stabilizer to provide outstanding thermal stability and precise machining.
  • machining center
    machining center
  • robotics
    robotics
