Revolutionize Machining: Tungaloy’s TurnFeed for Super High-Feed Turning
Experience maximum productivity and turning efficiency with Tungaloy's TurnFeed on steel. Engineered with a unique cutting edge for high-feed machining, this tool boasts double clamping technology for unparalleled rigidity and performance. The WPMT-ML Trigon insert with ML chipbreaker minimizes cutting force, while producing thin, manageable chips. Perfect for a broad range of applications, from roughing to finishing, thanks to its high versatility and resistance to wear and chipping. Transform your machining process today.
May 1, 2024
n
  • cutting force
    Engagement of a tool’s cutting edge with a workpiece generates a cutting force. Such a cutting force combines tangential, feed and radial forces, which can be measured by a dynamom…
  • chipbreaker
