Sandvik Coromant cast iron face milling demo
CoroMill 745 multi-edge cutter with high feed capability is in this demonstration used for face milling in cast iron. The 25 degree entering angle of this cutter version allows for high feed milling strategies to be utilized. The concept has a double-sided multi-edge design, making it a cost-efficient solution that delivers high productivity.
In this demonstration, Sandvik Coromant's CoroMill 745 multi-edge cutter with high feed capability is used for face milling in cast iron. The 25 degree entering angle of this cutter version enables the use of high feed milling strategies. The concept has a double-sided, multi-edge design, which is said to make it a cost-efficient solution that delivers high productivity.
n
