Basic endmill is anything but
Machinists find Haimer tool lasts longer, produces more.
Quickly and economically converting powertrains in Jeep vehicles is what Novak Conversions, Logan, Utah, has been all about since 1967. The company makes all its components in-house and always looks for ways to cut the time and costs of creating, designing, building and machining parts.
Novak applies endmills to rough alloy steel and carbon steel splining on transmission input and output shafts. Machinists were accustomed to short tool life and went through a lot of endmills.
Aaron Mikesell, applications engineer at distributor Herrick Industrial Supply Inc., Ogden, Utah, introduced Novak to the Basic Mill from Haimer USA LLC, Villa Park, Illinois.
The solid-carbide Basic Mill from Haimer USA can aggressively rough a range of workpiece materials and is available with (left) or without Safe-Lock shanks. Image courtesy of Haimer USA
"They tested it for about two weeks and a couple of different applications before we got feedback," Mikesell said. "It ran excellent. They were completely impressed with the speed and the life of the endmill. And on top of all that, they were extremely surprised with the price."
The test involved two parts. One required a plunge cut into 3⁄4"-thick steel before being finished with the same tool. Another part was made with a 3⁄8"-dia. endmill.
"It was like night and day," said Matt Olsen, machinist and CNC programmer at Novak. "We were blown away with the time savings and put it in one machine that we cut splines in. I was skeptical about the shafts. They are done in a lathe with a milling bit, but you don't even hear it. It's amazing. We've actually used them in manual applications, and the performance is insane."
Olsen has used the Basic Mill for almost two years, and the results continue to delight. When the old endmills were used during the customary busy season of January to July, Novak went through two or three endmills per week.
"Now we're still using the
ones that I bought three months ago," Olsen said. "It's a huge
improvement."
With the former tool, it took about 10 minutes to rough a transmission shaft. Using the Basic Mill, roughing takes about six minutes, a savings of four minutes per shaft.
"The biggest thing that I like is the cost," Olsen said. "A 1⁄2" endmill for $55? That's unheard of. They last forever. Lots of times, you can't even hear the endmill because it runs so quiet."
Before, Novak produced perhaps 50 parts in a day. With the Basic Mill, the number is from 100 to 120. The company also gets two to three times more life from each tool when milling big plates.
Olsen said a certain increase in sound indicates when a new endmill is needed.
"You can hear it and take the tool out and look at it on a microscope," he said. "The tools are usually fine. It's the coating on the tools that usually fails before the tool. Once the coating goes, you lose the edge. So we change it out right there and then. And with the low cost, you don't feel bad changing it out."
Finishing tools last quite a bit longer as well, Olsen said, because roughing tools last longer. When roughing tools take longer to start to fail, finishing tools do not have to work harder to make up for the roughing tools.
Mikesell said the production facility runs a lot of the same parts again and again.
"They really can look at it on a qualitative level," he explained. "The biggest thing for Novak was the performance-to-price ratio—what they got out of it for the money. That's really the same for all my customers."
About 30 Herrick customers use the Basic Mill for various applications. Mikesell said many companies use it as their general-purpose stock endmill because its price is hard to beat.
"I have it in play from aerospace to automotive to food and beverage manufacturing," he said. "It's used all over the place. It is a good endmill to do plug and play."
