Anglemaster-HD
Anglemaster-HD
Peddinghaus Corp. has introduced the newest member of the Peddinghaus Anglemaster family, the Anglemaster-HD.
Peddinghaus Corp. has introduced the newest member of the Peddinghaus Anglemaster family, the Anglemaster-HD. The Anglemaster-HD utilizes NEW Smart Cylinder technology which optimizes hydraulic fluid levels for accelerated production. Equipped with two 3-speed 169 ton (153 metric ton) punch cylinders with triple tool punches and one 515 ton (467 metric ton) 3-speed shear cylinder with single cut tooling, the Anglemaster-HD can process angles up to 8 x 8 x 1" (200 x 200 x 25mm) and flat bar up to 12 x 1" (300 x 25mm).
Equipped with Peddinghaus Roller Measurement technology, the Anglemaster-HD allows material to be stored outside until production takes place. This proven method of measurement provides benefits such as streamlined handling, and reduced overhead costs.
The Anglemaster-HD also comes standard with an automated material dimensioning system. This allows the Anglemaster-HD to identify the size of a profile and determine the length of punch or shear stroke required for maximum productivity. Utilizing this system, the Anglemaster-HD is also capable of verifying section sizes before initializing a program, resulting in a reduction in operator error.
With the development of the Anglemaster-HD, fabricators possess the ability to process detail components 50 percent faster than previous models, saving fabrication time and increasing throughput. Optionally equipped with part stamping or carbide scribing units, the Anglemaster-HD redefines the industry standard for angle and flat bar production.
