oelheld has been on the forefront of lubricant innovations for over 130 years. The company's R&D team in cooperation with machine manufacturers, universities and customers know exactly what to expect from water-miscible coolants and their challenges. Water-miscible coolants have many advantages over their straight oil counterparts, but they also have some well-known disadvantages such as corrosion (machines and parts), lubricity (tool life) and sump life (fungi, bacteria).
This has been the motivation for the R&D department to break new ground and develop new products that guarantee that most of these disadvantages are a thing of the past. These expectations, special requirements and problems have been taken care of as a result of this extensive R&D work, which resulted in the development of the AquaTec 7655 coolant.
The AquaTec 7655 is suitable for high-pressure applications or processing nonferrous metals. During the development of the AquaTec 7655, special attention was paid to process stability and the reduction of maintenance costs, as this offers an enormous competitive advantage for our customers when working at high capacity. The use of modern raw materials and therefore the compliance with the latest chemical laws, make the AquaTec 7655 a long-term choice.
With the new AquaTec 7655, the company took on these challenges and will improve your manufacturing process, as well as reducing your ongoing costs at the same time. By choosing the right coolant, you not only save time and money, but you eliminate your other concerns so you can focus on manufacturing.
Health benefits:
AquaTec 7655 produces low emissions
AquaTec 7655 meets the requirements of REACH
AquaTec 7655 has very good long-term stability
AquaTec 7655 is free from heavy metals and organochlorine compounds
AquaTec 7655 is an EP cooling lubricant concentrate containing mineral oil, which is suitable for almost all types of metalworking. Long tool life is achieved by special EP additives. The concentrate was developed to produce the highest surface qualities and is particularly low in foam and odor.
High surface quality of workpieces
Particularly low-foaming
Can be used with both high and low water hardness
Low maintenance and care requirements, saving you time
Contains no organochlorine compounds
High emulsion stability
Long tool life
Extremely high stability even without the use of additives
Excellent machine cleaning effect
Low air pollution for a better environment
No corrosion problems
Application concentration:
Machining of aluminum alloys 8 – 10 %
Heavy machining 8 – 20 %
Technical facts:
Color of the concentrate is brown)
Mineral oil content is approx. 45 %
pH-value of a 5% emulsion is 9.2
pH-value of the concentrate is 9.8
Corrosion protection 6% (Grade 0; testing method: DIN 51 360 T2)
Always put the concentrate into the water, not the other way round, otherwise no stable emulsion is formed. Since AquaTec 7655 is a high concentrate cooling lubricant, it is imperative to follow the correct sequence. The water hardness should not be lower than 4°dH and should not exceed 25° dH. A water hardness between 6° dH and 16° dH is ideal. Please do not use hot/warm water to prepare the emulsion.
AquaTec 7655 should be able to be mixed with most other cooling lubricants. In individual cases; however, it is advisable to contact the oelheld laboratory, which has tested a large number of competitor products for their miscibility.
AquaTec 7655 is suitable for processing all ferrous and nonferrous metals. It is not suitable for machining magnesium. When machining copper, a slight discoloration of the cooling lubricant may occur, but no discoloration of the workpiece. However, leaving copper/brass parts in the cooling lubricant for a longer period of time should be avoided. Cast iron can also be processed continually without any problems, e.g. EN-GJS-600-3 or EN-GJS-600-7. When machining aluminum, as well as steel, the tool life can be doubled by changing to AquaTec 7655.
AquaTec 7655 should be used with at least 7% in the machine. Your tools will thank you for it. Field reports of a customer turning V4A material: at 6% concentration the insert has to be replaced after 11 parts. After increasing the concentration to 10%, 25 parts could be machined with one insert. With the heaviest machining, where chlorine containing special greases were previously used, a concentration of 14% meant that additional manual greasing of the parts was not required at all.
Experience has shown that AquaTec 7655 is very stable and requires little maintenance. It is important not to let the concentration drop below 7%. In most machines, the cooling lubricant has not required changing since the switch was made to AquaTec 7655, in some cases for more than 4 years.
A dermatological expert opinion attests AquaTec 7655 to have a good skin compatibility. However, due to the alkalinity (pH value 8.8 to 9.2) you may consider skin protection on a case-by-case basis. This applies to all water-mixed cooling lubricants.
AquaTec 7655 is very low foaming. Flushing pressures of up to 80 bar with internally cooled tools are possible without problems (higher pressures are not usual in the industry).
The cooling lubricant must be monitored in accordance with TRGS 611 regulations and the application concentration should be checked using a hand refractometer.
- alloys
alloys
- aluminum alloys
aluminum alloys
Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wrought compositions and casting compositions. Some compositions may contain up to 10 alloying elements, but only one or two are the main alloying elements, such as copper, manganese, silicon, magnesium, zinc or tin.
- coolant
- emulsion
emulsion
Suspension of one liquid in another, such as oil in water.
- extreme pressure additives ( EP)
Cutting-fluid additives (chlorine, sulfur or phosphorus compounds) that chemically react with the workpiece material to minimize chipwelding. Good for high-speed machining. See cutting fluid.
- hardness
hardness
- lubricity
lubricity
Measure of the relative efficiency with which a cutting fluid or lubricant reduces friction between surfaces.
- metalworking
metalworking
- miscibility
miscibility
Ability of a liquid to mix with another liquid. See emulsion.
- refractometer
refractometer
Optical instrument that measures the refractive index of a liquid, such as a water-diluted metalworking fluid mix. The refractive index can by used to determine the concentration of a fresh metalworking fluid mix.
- straight oil
straight oil
Cutting fluid that contains no water. Produced from mineral, vegetable, marine or petroleum oils, or combinations of these oils.
- turning
