Benz LinA 4.0
Benz LinA 4.0
Benz Inc. has completely revised its broaching unit Benz LinA. With its new, compact design, the new Benz LinA 4.0 is lighter and much more rigid, yet capable of up to 1,500 strokes per minute. Easily fine-tuned and with a standard gear ratio of 2-1, this unit can power through many more materials with minimal or no vibration, greatly improving the service life of the cutter.
Internal coolant is possible even through the plunger. Improved materials guarantee tightness against leaks.
Inquiry to see how you can change the rotary motion of the live tool turret into a linear motion for broach and spline machining on any turning center, perform linear ID and OD broaching, machine splines, torx and hex shapes - all with the same live tool. Easily gather performance data with the added BENZ i.com feature, which is available on the new BENZ LinA 4.0.
