Carmex Precision Tools LLC's new BLU Grade thread turning inserts combine a newly developed sub-micrograin grade with PVD triple layer coating to deliver high strength, longer tool life, more accurate thread and better surface finish, even in the most difficult materials.
Available in a wide range of pitches and threads, BLU grade inserts provide higher value through improved performance, shorter cycle times, and longer tool life.
- turning
