![](/sites/default/files/styles/product_image/public/product_images/CimcoolTubeandPipe.jpg?itok=wkGhJ8af)
CIMCOOL Fluid Technology introduces a new and complete product line designed to meet the challenges of the tube and pipe industry. CIMMILL Fluids, reportedly formulated to increase productivity by up to 20 percent in tube and pipe operations, offer excellent lubricity, rust protection and sump life. Mills and processors will also experience excellent foam control, improved tool life and increased up-time during critical roll forming, cut off and threading operations. Increased productivity and trouble-free performance make CIMMILL Fluids uniquely qualified for tube and pipe operations.
"We have a history of success in tube and pipe operations, but our new CIMMILL Fluids are designed to significantly improve productivity. CIMMILL Fluids exceed key performance needs of tube and pipe mills while continuing our commitment to always provide operator-safe products," said Bruce Koehler, Cimcool Product Manager. "There are products in the CIMMILL line that cover a wide range of applications including the most severe. Whether in roll-forming, hydro-testing or critical threading operations, there is a specific product designed to run cleaner and more efficiently. CIMMILL Fluids were designed to be safe, increase up-time and provide clean working conditions."
- lubricity
lubricity
Measure of the relative efficiency with which a cutting fluid or lubricant reduces friction between surfaces.
- threading
threading
