![](/sites/default/files/styles/product_image/public/product_images/CimcoolCimtech310.jpg?itok=CX1u1jTR)
CIMTECH 310 from Cimcool Fluid Technology, a low-pH synthetic fluid designed to meet the stringent requirements of the automotive and aerospace industries, has become the standard metalworking fluid for many manufacturers. The product passes all bi-metallic and aluminum (7075) "sandwich" corrosion tests, the company reports.
CIMTECH 310 is recommended for machining and grinding operations, including creep feed grinding on non-ferrous or ferrous metals. Designed for moderate- to heavy-duty operations, CIMTECH 310 is low-foaming and provides excellent rancidity control, extending the life of the fluid and minimizing the need for additives.
CIMTECH 310 offers unmatched lubricity providing long tool life and outstanding surface finish; it is transparent, offering the machine operator uninhibited part visibility; and is non-irritating to the skin.
- feed
- grinding
- lubricity
lubricity
Measure of the relative efficiency with which a cutting fluid or lubricant reduces friction between surfaces.
- metalworking
metalworking
- rancidity
rancidity
Bacterial and fungal growths in water-miscible fluids that cause unpleasant odors, stained workpieces and diminished fluid life.
