CIMCOOL's family of metalworking fluids are specially formulated for the unique needs in medical manufacturing operations. They meet stringent quality, health and safety requirements for machining, grinding, stamping, metal-forming, cleaning, and many specialty applications that set new standards for industry performance. CIMCOOL products reportedly provide four to five times longer sump life; up to 40 percent improved tool life; an increase in productivity; excellent rancidity control; greatly reduced concentrate usage; and operator-friendly use.
CIMTECH 310, CIMTECH 315, CIMTECH 320-HFP Synthetic Metalworking Fluids: These low pH, low foaming synthetic fluids are recommended for high fluid pressure and high volume flow applications where foam minimization is critical for part quality and machine operations. They can be used for a wide variety of moderate to heavy-duty operations including creep feed grinding on ferrous and taping aluminum alloys.
CIMTECH 500, CIMTECH 510Z-HFP Synthetic Metalworking Fluids: Ideal in high fluid pressure and high volume flow applications where foam minimization is critical for part quality and machine operations on ferrous metals including stainless steels. CIMTECH 609G Synthetic Metalworking Fluid Concentrate: A hybrid synthetic developed for superior performance in heavy-duty grinding with close tolerance requirements. Although non-chlorinated, its performance exceeds that of most chlorinated soluble oils for stainless and titanium.
CIMTECH 610 Synthetic Metalworking Fluid Concentrate: This new, hybrid blend of patented and synthetic lubricants is uniquely formulated for hard metals like inconel, titanium, stainless steel alloys, aerospace alloys and hardened steels for use in heavy-duty to severe-duty machining operations.
CIMPERIAL 1060CF-HFP Metalworking Fluid Concentrate for High Fluid Pressure Applications: A chlorine-free soluble oil for high fluid pressure applications that is excellent for machining and grinding exotic alloys like titanium, aluminum, stainless, and iconel.
CIMFREE VG-920M Water Soluble Metalworking Concentrate Containing Vegetable Oil: Free of mineral oil, nonylphenol ethoxylates, and chlorine, this fluid is recommended for a wide variety of medium to heavy-duty machining operations including turning, tapping, and reaming on ferrous and non-ferrous materials.
MILPRO 860CF Straight Oil: A chlorine-free oil for grinding, broaching, gear shaving, hobbing, and other heavy-duty operations. Its lubricity on ferrous, stainless, and exotic alloys makes it an excellent choice for use in grinding ball sockets/hip joints.
OAK KOOL 1600 Synthetic Grinding Oil: This chlorine-free synthetic delivers superior oxidative stability for hard metals like titanium and performs well in Europe-style grinders.
PRODUCTO SP-621 Parts Cleaner: Free of phosphates, halogens, or solvents, this fluid is ideal for dip tank, ultrasonic and low-pressure spray applications and is acceptable for nuclear applications. It will not streak, smear, or dull finish and is especially recommended for aluminum, titanium, stainless steel, and various types of plastics.
PRODUCTO SP-530 Parts Cleaner: This non-foaming cleaner at over 120°F in high pressure washers is recommended for aluminum, ferrous, and yellow-metal parts and is ideal for ultrasonic cleaning. It provides superior stain control, is corrosion resistant, and will not streak, smear or dull surfaces.
- alloys
alloys
- aluminum alloys
aluminum alloys
Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wrought compositions and casting compositions. Some compositions may contain up to 10 alloying elements, but only one or two are the main alloying elements, such as copper, manganese, silicon, magnesium, zinc or tin.
- broaching
broaching
Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
- feed
- grinding
- lubricity
lubricity
Measure of the relative efficiency with which a cutting fluid or lubricant reduces friction between surfaces.
- metalworking
metalworking
- rancidity
rancidity
Bacterial and fungal growths in water-miscible fluids that cause unpleasant odors, stained workpieces and diminished fluid life.
- stainless steels
stainless steels
- tapping
tapping
- tolerance
tolerance
- turning
- ultrasonic cleaning
ultrasonic cleaning
Method of cleaning metal or plastic parts by immersing them in an aqueous or solvent-based cleaning solution and imposing ultrasound energy on the bath to enhance cleaning by creating cavitation conditions at the part surface, which imparts a strong scouring action to remove tenacious soils.
