Delivering exceptional versatility and high efficiency, the Palmgren Combination 6 x 14-inch Finishing Machine is designed to meet the needs of the end-user. What differentiates this machine from the competition is its overall design which was built around actual user feedback.
The combination finishing machine is really two machines in one because it can handle a multitude of jobs that include contour part finishing, flat stock finishing, polishing, grinding and deburring—virtually any finishing operation. The belt arm adjusts vertically, horizontally and any position in-between. The belt section is mounted directly to the motor shaft and the graphite pad is replaceable. The machine features advanced easy belt tracking and quick, easy belt changes.
The #9681108 Combination Belt & Disc Finishing Machine from Palmgren features a powerful direct drive power train, an adjustable guard for both the belt and disc sections and a single dust collection port for both sections for easy connection and cleaning.
- flat ( screw flat)
flat ( screw flat)
- grinding
- polishing
polishing
