Compound RP-99S Rust Preventive
Madison Chemical introduces Compound RP-99S, a versatile water-based rust preventive for use on ferrous and copper metals. Applied to previously cleaned parts by immersion, manual spray or recirculated spray methods, Compound RP-99S leaves a nearly invisible, dry-to-the touch film that provides short-term indoor storage protection for treated parts lasting up to four weeks, or longer depending on concentration.
Madison Chemical introduces Compound RP-99S, a versatile water-based rust preventive for use on ferrous and copper metals. Applied to previously cleaned parts by immersion, manual spray or recirculated spray methods, Compound RP-99S leaves a nearly invisible, dry-to-the touch film that provides short-term indoor storage protection for treated parts lasting up to four weeks, or longer depending on concentration. The water-based compound contains no oil or solvent, resulting in low use cost.
Compound RP-99S is safe for ferrous and copper alloys, when used as directed. For most applications, Compound RP-99S is used at 2-10% by volume in water varied from 70° to 160° F. Heating the solution will lessen the time required for drying and may improve overall protection results. Treated parts should not be stacked or nested together until dry. Concentrations up to 15.0% may be used for longer rust protection time.
It is also used as a deburring compound in barrel and vibratory equipment for mass finishing operations. Compound RP-99S provides detergency to keep mass finishing media clean and remove light oil and metal chips from parts. It also promotes the sinking of suspended particles and floating of oil for increased tank life of recirculated solutions. Compound RP-99S is used at 1-5% by volume in water for mass finishing applications.
