E-Series Mill-Duty Vacuum Lifter
A heavy-duty, high capacity vacuum lifter that is designed for handling heavy ferrous and nonferrous plate and sheet from the top for loading cutting tables is available from Anver Corp.
May 12, 2012
The Anver E-Series Mill-Duty Vacuum Lifter lets one person handle all ferrous and nonferrous materials including stainless steel and aluminum clad parts; one plate or sheet at a time, from the top without magnet beams, chains, and hooks. Featuring an all-welded steel frame and fully adjustable cross beams, this rigid lifter can be integrated with an overhead crane, incorporate redundant power stations, and be set up for radio control.
Custom built with capacities up to 60,000 lbs. and multiple rectangular or round suction cups and double spring suspensions, the Anver E-Series Mill-Duty Vacuum Lifter can handle steel plate up to 80 ft. x 8 ft. Standard features include a pendant control that requires two-hand operation and if there is a loss of power it has a self-contained vacuum reservoir, check valves, and a leakage sensor with audio-visual alarms.
Anver E-Series Mill-Duty Vacuum Lifters are priced from $30,000.00 up, depending upon capacity.
