ESPRIT 2016
ESPRIT 2016
ESPRIT 2016 from DP Technology Corp. features a new innovative high speed lathe roughing strategy, called ProfitTurning that implements ESPRIT's new physics-based cutting engine. While traditional cutting strategies only consider the geometry of the part, ProfitTurning creates the toolpath considering multiple cutting factors and machine characteristics that impact machining performance.
"ESPRIT 2016's ProfitTurning remarkably improves chip control on hard materials, such as titanium and Inconel. In addition, ProfitTurning reduces irregular cutting forces and vibration tendencies. The net result is a drastic reduction in cycle time, up to 50 percent more compared to traditional cutting methods," said Cedric Simard, global marketing and communication director at DP Technology.
Simulation speed also plays a pivotal role in CAM software and ESPRIT continues to be at the forefront of accelerating simulation without compromising accuracy or stability, according to the company. ESPRIT 2016 includes increased simulation speed and higher quality surface finishing saving the user valuable time. Advanced tool settings in ESPRIT 2016 provide CAM programmers enhanced tool management solutions. Additional barrel tool support has also been extended to cover more 5-axis and 3-axis cutting cycles. Furthermore, cloud-enabled ESPRIT supports the MachiningCloud app, which enables users to retrieve ideal cutting tool solutions and import them directly into ESPRIT with ease.
ESPRIT 2016 also features enhanced CAD-recognition functions to correct and detect any acute unseen defects in imported CAD models. In addition, users can now edit or remove fillets or even extract a spine curve from fillets as a tool drive curve in machining operations. The new hole-feature recognition features in ESPRIT 2016 include automatically recognizing different types of complex holes and names them accordingly. ESPRIT also measures the curvature angle of open holes, making complex drilling operations more accurate and productive.
Wire EDM improvements in ESPRIT 2016 make rough cutting easier and prolong tool life. The optional cut-off clearance in ESPRIT specifies additional clearance for cut-off moves to reduce the amount of grinding required. Another new Wire EDM feature is the optimize first cut-off, which protects the wire from rethreading where there is no predrilled thread hole.
Fluid 5-axis features in ESPRIT 2016 eliminates unwanted plunge-type moves in swarf cycles, and smooths any concealed defects in spiral finishing part surfaces. The feed rate of spiral roughing can now also be increased for noncutting moves to save cutting time. ESPRIT 2016 accelerates machining with increased simulation speed and innovative cutting strategies that save users programming time and optimize profits.
