Expanded Range of Jetstream Tooling Holders
By placing high-pressure coolant directly in the cutting zone, JETI technology ensures superior chip and temperature control. For further process optimization, holders equipped with Jetstream Tooling Duo feature a second coolant outlet from the clearance side that can be turned on or off depending on part-processing requirements.
April 27, 2020
Seco Tools has announced the expansion of its Jetstream Tooling Integrated (JETI) technology with a complete range of holders for General ISO turning. This easy-to-use internal coolant technology increases tool life dramatically while also shortening setup and indexing times thanks to a new single-screw insert clamp design and the absence of external hoses.
By placing high-pressure coolant directly in the cutting zone, JETI technology ensures superior chip and temperature control. For further process optimization, holders equipped with Jetstream Tooling Duo feature a second coolant outlet from the clearance side that can be turned on or off depending on part-processing requirements. As a result, manufacturers can run much higher cutting data without impacting application security for any ISO-S, ISO-M or ISO-P turning application.
First introduced for MDT, X4, 150.10 and Snap-Tap® holders, the expanded range of JETI for General ISO holders includes 182 new products for all inch, metric and Seco-CaptoTM holders.
